Double tap to wake is back!
iArvee
Glad to see that double tap to wake is back! Not like the XZ3 where it just turns on ambient display, but now takes you to the lockscreen like the older phones.
13 ANTWORTEN 13
joima
maybe we can use imgur?
https://imgur.com/
drlmiles1
Vielschreiber
Here's the screenshot in System/Gestures
joima
Thank you,drlmile
Let's wait for the moderator to approve the photo.
Jonas
Meister
Hello everyone and I'm glad to hear that all of you are happy that the "tap to wake" function is back! Slightly_smiling_Face
@Lutkis, you can find the setting in Settings > Lock screen & security > Lock screen preferences > Tap to show lock screen > "On", or in Settings > System > Gestures > Tap to show lock screen.
Not really sure why the setting is in two places since it does the same according to what I have tested at least (even the setting is called the same).
@azzido2, that's a good suggestion! You can always use the kudos button instead of replying as an alternative, if you prefer using that instead! Slightly_smiling_Face
@Jonyny, the setting can be found in, Settings > Lock screen & security > Lock screen preferences > Tap to show lock screen > "On", or in Settings > System > Gestures > Tap to show lock screen.
@joima, the picture has been approved, it was the last thing I did on Friday, but it takes a few minutes for it to show up even after it has been approved by Staff/Moderators! Slightly_smiling_Face
Thanks again all for the feedback as it is very valuable to us!
