alpha 7 s iii 3.00 Problems with ISO in Slog3 and RAW HDMI output
profile.country.RO.title
ionbadescu
Member
Hi,
On the Sony a7siii there's a problem when outputting HDMI RAW. The lowest ISO becomes 640 and the 1600 is the only clean ISO in the range that is looking like 12800 ISO Slog3 in camera.
You can't shoot lower ISO than 640 in HDMI RAW and it's not even the true 640 ISO that the camera can shoot internally.
This issue persists in Slog3 if you have the ISO set to AUTO.
Clearly a big bug that needs to be fixed.
If anybody else has this issue, please write it here so Sony can do something about it.
3.00 firmware RAW HDMI output ISO error on a7siii
9 REPLIES 9
profile.country.IT.title
danardi78
Thanks @ionbadescu
I know that it’s a nonsense, but I must ask before to escale your case: do you have tried to reset to factory after fw update? Have you checked every single settings about video recording?
danardi78
PS: are you sure that you had be able to go at lower iso than native in raw before the upgrade? 🤔
ionbadescu
Member
I have recorder RAW out of my camera in many occasions. I have ample vidros on the a7siii on my YouTube channel. I was able to record lower than 640 and there where always 649 or 800 and 12800 clean ISOs. Now it’s just 1600 that’s behaving like 12800. After update I wrote to sony and got a list of steps to go through so I can check if it fixes the issue. I did everything they asked and it didn’t work. So. Give us a fix.
ionbadescu
Member
As you well know, the update turns everything to factory settings to begin with. You loose all you previous settings and the camera acts as a brand new one. I also reseted the camera when I saw the glitch but it didn’t fix anything.
danardi78
I know, but I have to ask otherwise it’s the first answer from support and we lost weeks in unuseful questions.
I escaled your issue, don’t expect a solution or a great answer, but we point on the quantity of claims escaled to move something :slight_smile:
There are a lot of issues with last update, for sure a fix update will arrive. My interest is to insert the more arguments we can to fix all issues 🖖
ionbadescu
Member
Thank you.
ionbadescu
Member
Hi. I did everything possible. I respected all the steps that I’ve been instructed to take. Including resetting the camera after fw update and checking all settings. The ISO issues are still there. There are many in the reddit community that have the same issue. They all tried.
ionbadescu
Member
Hi.
As a videographer, I depend on my camera to work with all the features it comes provided with. This 3.0 update robbed me of these features: The AUTO ISO in any slog PP mode and RAW output. It is a big issue. I knowyou guys work with the majority rules. But I paid good money on a camera thaty advertises those features. How am I supposed to continue wiht this camera? The majority rule gives me no alternatives.... Any ansewrs? Any Sony concerns for those that shoot raw out of this device?
The silence gives me the impression that Sony doesn't care.
ionbadescu
Member
to the "are you sure you that you had be able to go at lower iso than native in raw before the upgrade" question:
How are you an expert on Sony cameras? Look at the specs first.
