Sony A1 movie files
gbodave
New
Sony A1 movie files
Where are movie files located on SD card please ?
3 REPLIES 3
IamNic
Hi @gbodave,
not too sure if the alpha 1 kept the file structure - easiest way to find the files is to perform a ".mp4" search on the full directory of the card and then right click any of the results and use the context menu option "open file location".
- Nic
gbodave
New
Did that - nothing found.
There is a YT video about movie files being buried deep down in the SD file structure for earlier Sony models. Nothing for the A1 though.
When you look at the files in Windows Explorer only RAW files are displayed (I only shoot RAW stills) but a couple of test videos I'd done with the camera don't show up.
danardeng
Contributor
YT videos?!?
You brought a professional gear, please move as a professional.
You have to search on the right position, don’t use automatic import systems.
Official manuals can help https://helpguide.sony.net/ilc/2040/v1/en/contents/TP1000409199.html
