Sony a1 - Wifi standy stuck
MrSerious
New
I bought a Sony a1 about two years ago. I've had no issues with the camera. I particularly liked the remote shooting capability. I downloaded the Imaging Edge app and was hooked.
Then a month a go the camera got stuck in the wifi standby loading screen and has been stuck since. It never gets past the loading. Has anyone experienced this and know what to do? Is it a physical issue and not firmware. I have not upgraded firmware, so am running the original version.
1 REPLY 1
Piscie
Community Team
Hi @MrSerious, have you tried ejecting the battery for a few minutes, then reinserting it and checking again? If that doesn't help, try resetting the camera from the settings. Also check that your TV is running the latest version, it should be Ver. 1.32.
