Freeview TV Guide double channels
SOLVED
Prior20
Member
so for months everything has been fine, youview is a distant memory along with 99% of the issues.  Until yesterday
https://photos.app.goo.gl/QTUzyXiktsDvig5i7
two sets of each channel, tried the usual soft / hard reset, ideally dont want to reset everything
1 ACCEPTED SOLUTION
Accepted Solutions
Prior20
Member
5 REPLIES 5
Prior20
Member
mrswanny
New
Just had the same issue, freeview guide showed duplicate channels and couldn't scroll through the guide.
Retune digital channels fixed the issue.
Also agree that You View has to be turned off or the TV is unusable - can't wait until it breaks and I can buy something other than a Sony - NEVER AGAIN!
jbcrammond
New
Yes that worked for me too but a few days later ....  the duplicated channel numbers(blank) were back...  you can still scroll up and over and come up from the bottom but you can't scroll down ... no doubt a retune will reset it again but then you have to re-order your channels as you prefer them .. pain !!!
HannahEd01
Community Team
Hi jbcrammond, try returning without the aerial then with it once and let me know the outcome. ^^
jbcrammond
New
Hi HannaahEd01
Ok tried that and been waiting to see if it lasted any longer than a standard re-tune which fixed it for a while the last time.
Yes it worked but unfortunately it has just done it again on switch on  ... same duplication of channels by number - one with details other corresponding entry blank
Also as someone else previously mentioned unable to scroll down to select channels , however you can scroll up over the top and scroll up from below to select any channels above
annoying more than anything
Thanks for the input
JC
