отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
iplayer outside UK with Sony Android Bravia TV
РЕШЕНО
rolandscriven
Исследователь
Hi,
I have a fairly new KDL-43W805C Sony Android TV. I'm outside the UK but use a smart VPN DNS. It seems with most other TVs (including old Sonys) this should be enough to get UK apps like Iplayer and Demand 5. You just change your settings and "refresh internet content". However, it seems that this is impossible with the new Sony Android TVs - is this true?
Is there anyway to get iPlayer and Demand 5 to work?
Thanks
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
rolandscriven
Исследователь
Hi,
I figured it out. After setting up the smart DNS - if you clear data and cache from the sony select app and then restart it - it works a charm!
5 ОТВЕТ 5
rolandscriven
Исследователь
Hi,
Thanks. It's not a VPN but a smart DNS. Sorry, my mistake for getting that wrong. And I have the iPlayer working fine - just the normal Android version - where I have to use the mouse. In Sony Select I also see other apps like Sky TV etc being offered. I was just curious if there was a way to enable the native app in Sony Select? Or could you tell me what steps I might take if I were in the UK?
Many thanks
rolandscriven
Исследователь
Hi,
Anonymous
Неприменимо
Excellent.  Glad you got it sorted.
curtberry
Новый
hello im still having trouble getting the iplayer app to appear in sony select i have set up a smart dns and cleared the cash and data.
any help would be grate
thanks
