One Click Programme Guide ?
profile.country.IE.title
l0stie815
Hi all, new to the forum have decided to use the programme guide with free to air and streaming channels works great no complaints but when browsing through the guide and click a channel I have to wait like 10 seconds for the event info to load before I can click view anyway to just disable this pop up and go direct to a channel while using the guide ?
4 ANTWORTEN 4
Anonymous
Nicht anwendbar
Hi there,
Welcome to the community. :slight_smile:
Which product do you have?
Best wishes,
M
l0stie815
Hi thanks for the reply sorry it's a KD-49XD7005 and im using the built in guide and browsing through I have to press the middle button then I have to wait for the the info to load before the view button can be selected and I can enter the channel I'm trying to disable it so its just one click.20180704_133648.jpg
l0stie815
Hi, So can you help ?
Almou_10
Spezialist
Hi l0stie815,
This message is normal with the TV's guide and I think there is no way that you can access the channel without passing by this window.
Cheers,
Almou_10
