- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I have found under Settings, External Input, you can configure the TV button, Howeve this function is greyed out and not selectable. How do I configure this to use HDMI1 input as default?
TV is SONY BRAVIA KD49XD8305BU
Thanks.
Gelöst! Gehe zu Lösung.
Akzeptierte Lösungen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi there
This option is unavailable in YouView mode. YouView would need to be disabled to use this feature.
I have just tested to see if you could disable YouView, change the setting and then re-enable YouView again - unfortunately not, it goes back to the default 'Digital' input doing this.
Cheers
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi there
To disable YouView
- Press [Home] button on the remote control
- Go to 'Settings'
- Go to 'Channel Setup'
- Go to 'YouView Setup'
- Select 'Disable YouView'
- Select 'Yes' to confirm
Cheers
PS: You're Welcome
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi there
Cheers
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for the very quick reply Quinnicus.
Can you let me know how to disable YouView please - only got the set recently and havent navigated all menu's!
Many thanks for you help.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
