- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Bravia remote not connecting to TalkTalk Youview box
Hi, my Sony Bravia OLED tv seems to now have lost connection with my TalkTalk Youview box. Have tried everything from full power drain, factory reset of TV to re-pairing from start but none of these approaches have worked. On initial set-up the pairing of my Sony remote to the Youview box was straight forward and worked - so not sure why this has now stopped and cannot re-sync - anyone experienced this? Thank you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello @ jb61775, which TV model have you got? and what is the connection method? Are they connected with HDMI cable?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Piscie, thanks for coming back. Model number is KD-48A9 and connected via HDMI. It did work when I first set-up the TV but as mentioned, for some reason has stopped and I have not done anything to trigger this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @jb61775, Did you try to connect it to a different HDMI port or use a different HDMI cable for example?
Also, make sure that your Bravia sync settings are toggled on so that your external devices will sync to your TV, i think it should be under the external inputs section through settings.
