SONY KD-55XE9003 (2017) vs 55XD9305 (2016)
profile.country.NO.title
Steelduck
Hi.
Wich one of the 55XD9305 and 55XE9005 will give me the best picture quality, when playing Blu-Ray and 4K HDR movies?
Planning to by one of those.
Whats the main difference between these screens?
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
cass_n
Community Team
Hi @Steelduck and welcome to the community,
If you go to https://www.sony.co.uk/electronics/tv/t/televisions you can select both TVs to view them in a comparision chart, which makes it easier to see the differences.
I would say that the XE90 is your best option, as it comes with the newer Android OS (Nougat).
I hope this helps.
Cheers,
C
4 ANTWORTEN 4
Pascale_F
Moderator
Hi Steelduck,
Thanks for your message. We are looking into this and someone will get back to you shortly.
Thanks,
Pascale_F
cass_n
Community Team
I hope this helps.
Cheers,
C
Steelduck
Thanks!
I got a demo of them both, and bought the XE9003.
Both had very good picture quality, but the XE9003 had "better light conrol" in HDR it seemed.
cass_n
Community Team
Glad to hear it!
