Up until yesterday all was working well, using my tv remote as my sound control with my HT-RT5. Turned the tv back on later and found that the tv remote will no longer operate the soundbar. I have tried every setting, bravia sync,optical, HDMI leads etc, and still no joy. Yes I can use the soudbar remote and it will operate then soundbar ditto with the tv remote on tv settings, but it's doing my head in trying to sort this out. Also I updated both the tv and soundbar software in the last month, and no problem until now. Please help if you can as my head is going to explode lol
Gelöst! Gehe zu Lösung.
Hi there
At this stage, I can only suggest you going back to basics and reset both the TV and HT-RT5 soundbar back to factory default settings and start again.
Also have a read of:
https://community.sony.co.uk/t5/android-tv/hdmi-problems-troubleshooting-steps/td-p/2141941
Cheers
Hi there
Cheers
I will try that bud. Thank you
