SONY xh950 yellow-white light
profile.country.GR.title
karamo90
Explorer
Hello i have a 55' sony xh950 and i see that a yellow and sometimes a white amber light is turning on left from the sony logo.I used some tricks like changing the time set from 24 hr to 12 and back but it keeps turning on on different times and sometomes i see the red light from the side digital port when the Tv is turned off turning offline and online and then the yellow amber  light  comes back to "life".Any permanent solution?!
1 REPLY 1
Joe_Dohn
Specialist
I believe this is what you're looking for.
