I forgot my pin password and how to reset
SOLVED
qhairulvale
Visitor
hi, i want to ask how to reset xperia e dual , without open menu , please help me admin and other user !! i cant open my homescreen how to reset or bypass or anything . thanks , i hope please reply fast Thinking_Face
1 ACCEPTED SOLUTION
Accepted Solutions
Sam
Legend
Legend
Try this:
To repair the phone software
1.     Install PC Companion on a Windows PC from Support
2.     Turn on the phone, and connect it to the PC using a USB cable.
3.     In PC Companion, under Support Zone and click Start.
4.     Under Phone Software Update, click Start.
5.     Click repair phone.
6.     Follow the on-screen instructions.
What are your thoughts about this forum? Let us know by doing this short survey.
20 REPLIES 20
Sam
Legend
Legend
Try this:
qhairulvale
Visitor
Please help me , i need to use my phone .
qhairulvale
Visitor
Hello sam , i have reset or format my phone using software update from sony . Thanks Slightly_smiling_Face
hamza123
Visitor
what intructions did he give you,i have the same problem
Sam
Legend
Legend
@hamza123 - Please scroll up, the answer is the first response to the question.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
kwatt
Visitor
how long is this process meant to take?
Amano-Kun
Visitor
Thanks for the method sir
1246
Visitor
same
lockedphoneuser
Visitor
Worried_Face i also having the same problem and now im following these steps its saying preparing the computer for software update and loading......hope it works... I REMEMBER THE PASSWORD BUT I'VE PUT A SMILEE AS MY PASSWORD AND THERE WAS NO SMILEE OPTION INTHE UNLOCK SCREEN SO IM STUCK.....
