I got a Sony GTK-XB7 audio device with a broken 40GHX2240-MAF2G panel. According to the service, Sony no longer manufactures parts for it. Should I throw out the expensive device? What about the 10-year parts supply obligation?
Can somebody help me ?
Gelöst! Gehe zu Lösung.
Hi !
Yes, I got an answer from my support representative that Sony no longer makes parts for my audio device!
-toonika
When you say "according to service" which service are you referring to here? Authorized Sony service centers or 3rd-party?
Also, have you tried reaching out to the support reps directly?
- JD
I need parts too
It seems that Sony doesn't have parts for that anymore, maybe you can check with 3rd party store for available spares
