Trying to set up two Sony SRS-XB13 bluetooth speakers to have stereo output from my turntable
AlexanderXL5
Hi Folks,
I do hope someone out there knows the answer to this conundrum and can put me out of my misery.
I've successfully paired one Sony SRS-XB13 bluetooth speaker with my lovely Sony PS-LX310BT turntable, enjoying my vinyl records through this one speaker. But now I am trying and trying and trying (so far without success) to pair a second speaker so that I can have stereo from my record player.
Now, honestly, I have really tried (carefully following the instructions provided by Sony) to get the two speakers paired. But my second speaker is playing hard to get.
If anyone has any advice, I'd be thrilled to hear from them.
Peace and Love.
6 ANTWORTEN 6
Anonymous
Nicht anwendbar
Hey @AlexanderXL5
Did you follow the steps here? https://helpguide.sony.net/speaker/srs-xb13/v1/en/contents/TP1000200014.html
Make sure that after connecting 2 SRS-XB13 speakers, perform the pairing procedure between your turntable and the speaker in which the (BLUETOOTH) indicator is flashing in blue.
Steve666
I have followed the instructions to the letter, but still no getting my two speakers to Stereo Pair, if anyone has any more suggestions please help.
Anonymous
Nicht anwendbar
@Steve666, did you try to initialize it and try again?
Steve666
Hi, yes thanks, I have initialized both speakers a number of times but still no success
Anonymous
Nicht anwendbar
@Steve666, Did you try to connect other speakers to the turntable and other devices to your speaker. Does it work ?
pa_jesss
The issue seems to be related to Bluetooth limitations, as many devices only support connecting to one speaker at a time. To get stereo sound, you'll need a Bluetooth transmitter that supports dual audio output, or check if your player supports two Bluetooth connections at the same time.
