Hi all, has anyone experienced this issue before?
I have my WDTV Live SMP connected via HDMI v.1.4 to my Sony STR-DN1040 AV\Receiver but I am only getting PCM sound output!!! The Sony unit is not receiving any Dolby Digital signals from my SMP at all.
I have checked the audio settings on both devices and they appear to be configured correctly. It's not the HDMI lead as I have tried several.
Hopefully this screenshot may help diagnose my issue. I have a number of my movies recorded in this format but I'm not very knowledgeable about the various codecs. Should I be obtaining Dolby Digital sound from these files?
Codec Info Source - VLC Media Player
Puzzled!
Gelöst! Gehe zu Lösung.
Maybe I shouldn't have asked, I'm confused already!
What I want to do is convert my movies that have already been encoded as AAC inside the MP4 container, I think that's how you explain it.
Following on from your advice, I had already read the link you sent me but it's a little confusing for a novice such as myself.
Here's what I have changed it too following your advice below.
I've set downmix to Dolby Prologic II as suggested but I have 2 options for the codec, AC3 PassThru or AC3 (ffmpeg).
Can you be a little more specific with what settings I should change please?
I'll buy you some cheese!
Ok, I think it 'might' be best to try it twice as a test run and see which one works best - before converting the rest. Then you see which one 'works' best (hopefully)
Test 1
Source = 1 English (aac) (2.0 ch)
Codec = AC3 (ffmpeg)
Mixdown = None
Leave rest as defaults
Test 2
Mixdown = Dolby Pro Logic II
Don't use AC3 Passthru for this.
@Quinnicus wrote:Ok, I think it 'might' be best to try it twice
Test 1
Mixdown = None
Test 2
That's better, I'll make a teacher out of you yet!
OMG.., I'll be needing advice on how to tie my shoe laces next!
I'm going to try test 2 first, I'll report back tomorrow with the results
Thanks again mate.
No problems - and good luck
Teacher, pfft
I recommend the tests before converting the rest (as I dont have your exact setup, so hard to know what outcome maybe) and it saves time in the long run. Hate to convert all vids, and then it doesnt work (done it myself!)
Oh dear..!
I had to stop test run after 5 minutes, my AMD Phenom quad core processor was sitting at 100%. I'm not sure leaving it like that for over an hour will do it any good?
Its perfectly normal
My dual core laptop does the same - and boy does it throw out some heat. Ive had large batch runs process overnight, and still going by the next morning (8 or so hours later) LOL
Phew!
Thanks for that, I've always been a little worried about such things because some programmes I've seen will shut the system down if high CPU is detected for too long.
I'll try it again later, just off out to pot my tomatoes up.
Ta ta..
Back again!
I adjusted my machine's performance settings using ASUS EPU4 Engine too 'Performance Mode', I think it made a difference..
Although CPU stayed at 99-100% throughout the CPU temperature did not go beyond 54 degress C
(usually it is around 38 - 40 degrees C - no load)
The original MP4 file was 827 MB
New AC3 encoded file is 1.24 GB
Here's the VLC Codec Info - It looks right to me and sounds good on my PC
I will test on the DN1040 later
Cheers again Quinnicus - Lucky Star Awarded!
Cool - sounds about right, AC3 will increase the filesize.
