Sony HT-CT80 sound drop out intermittently
SOLVED
debsuz600
New
I have used this soundbar since Dec 2015 and when playing Blu-ray or DVD discs, the sound drops out intermittently, for a few seconds.  I have noticed that this problem appears on other Sony Soundbars.
Connections, Optical Audio out cable
Blu-ray Sony BDPS1500 HDMI Gold cable
TV Bravia 32CX523 HDMI
At the moment I have changed the optical cable from the one supplied by Sony, to a thicker one purchased online.  I will update this post if that has solved the problem.
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
debsuz600
New
CHanging the optical cable and swapping the blu ray player for a newer model did not fix this sound issue. In fact it was getting more and more noticeable. Returned to store for a full refund after three months use. :worried:
3 REPLIES 3
Anonymous
Not applicable
Hi there
Just curious if swapping the cable solved your problem?  Or are you still experiencing audio drop-outs?
Cheers
debsuz600
New
Anonymous
Not applicable
Thanks for replying back.  Its a shame you couldnt get working properly 😞
