STR-DN1080 Dolby Atmos Issues
SOLVED
Pauliepnutz
Explorer
I have just discovered that Dolby Atmos is no longer working when playing 4K Ultra HD Discs (with Dolby Atmos audio) - my STR-DN1080 now displays (the core) 'Dolby True HD... ' (whereas 'Dolby Atmos' was always displayed previously). I have checked several 4K Ultra HD discs (all with Dolby Atmos audio), including 'Apocalypse Now Final Cut' which played recently - say, a couple of months ago - without any issues, and 'Dolby True HD... ' is now displayed for each disc.
My setup: STR-DN1080 AV Receiver, UBP-X700 Ultra HD Blu-ray player, KD55AF8 TV and Focal Sib Evo 5.1.2 (FD) speakers. I have used this setup for some 18 months now without any Dolby Atmos issues whatsoever so I am puzzled as to why Atmos is no longer working (although I suspect an update for my KD55AF8 TV may be causing the problem... ).
Any help would be much appreciated!
1 ACCEPTED SOLUTION
Accepted Solutions
Pauliepnutz
Explorer
Solved - it turns out that my chosen sound field (A.F.D.) was being switched to the '2ch Stereo' sound field (despite TV 'Sound mode sync' - "The sound field of the specified audio system will switch automatically when the TV's sound mode changes" - being disabled).
5 REPLIES 5
Sean_Mc
Moderator
Hi there,
I'm looking into this and will update the thread when I have an answer.
Best wishes,
Sean
Win_88
Specialist
Hi Pauliepnutz
Here's what I found in the Help Guide:
Dolby Atmos is decoded as Dolby TrueHD or Dolby Digital Plus when a sound field other than [Multi Ch Stereo], [A.F.D.] or [Dolby Surround] is selected.
Make sure to change the Sound field settings to one of the mentioned.
Here's a link to the page I quoited: https://helpguide.sony.net/ha/strdn108/v1/en/contents/TP0001273218.html
Win_88
Pauliepnutz
Explorer
Hi,
Thanks for your reply.
I am aware of that Help Guide page - A.F.D. is always my first choice for multi-channel content (and is the sound field I choose for Dolby Atmos), so I remain baffled!
Pauliepnutz
Explorer
Hi Sean,
That would be much appreciated! In the meantime, I will recalibrate and double-check everything (and try playing some DTS:X titles)...
Pauliepnutz
Explorer
