Anyone has battery issue? When battery reduce below 40%
SOLVED
MicHelloWorld
Visitor
When battery reduce below 40%. It will change battery status from 40% to 1% and then shutdown automatically.
Does has any experience? or know how to fix. Please recommend me.
Thank you.
1 ACCEPTED SOLUTION
Accepted Solutions
Arnab
Enthusiast
Charge to 100 %. Switch off then for 10 mins. And restart. Should solve the issue. Did you do this before?
6 REPLIES 6
Arnab
Enthusiast
Charge to 100%. Switch OFF. Keep like this for 10 mins. Switch ON. Most probably charge will be less than 100%, this is due to a small calibration mismatch. Its solved as of now. If you face this too much, repair using sony update service.
MicHelloWorld
Visitor
Hi Arnab,
I charged 100% every time. It's take the time about 1-1.30 hour to 100%.
Arnab
Enthusiast
MicHelloWorld
Visitor
No, I never did that before.
What you mean "switch off". You mean shutdown phone or unplug the charger?
Sorry for my english. And Thank you for your answer Slightly_smiling_Face
Arnab
Enthusiast
shutdown phone
MicHelloWorld
Visitor
Hi arnab, It seem your solution is work.
Now my battery is 28% and it's not shutdown.
Thank a lot. Slightly_smiling_Face
