Customizing Led notification light?
SOLVED
Eibbor09
Visitor
Hi there, Just want to know if theres any option of changing how fast the led light blinks.. because when im getting SMS, Im finding the blue led light notification too slow.. is there a setting or an app that will allow me to make the blinking more faster specially when I am getting SMS... Thanks in advance.
1 ACCEPTED SOLUTION
Accepted Solutions
zhuhang
Visitor
Its not in phone settings. But u can download third party apps from google play to customize it.
There's plenty of it out there, so i can't tell which is the best. But probably u need root first.
2 REPLIES 2
zhuhang
Visitor
Nabeel
Master
There are no settings for the same within the mobile itself.
As zhuhang said above, you might need an app for it
