Hi,
Thursday my XPERIA S was accidentally dropped in washbasin.
Display is working fine, everything works fine but, touch is not working. Keys power on, display, volume up/down and camera keys are working. Warrenty is void as it was liquid damage.
Gave cell to Sony Authorized service center, they cleaned phone and said connector part from display is corroded and total screen needs to be replaced.
Can that corrosion be cleaned up? They cleaned it, earlier it down left was bit darker now that issue is not there but still touch is not working.
Can anyone suggest what to do next? Really miss the phone!
Thanks,
iMindG
Gelöst! Gehe zu Lösung.
Saw that, but it doesnt talk about XPERIA S.
Does Xperia S also comes with seperate digitizer?
Pleaase let me know.
Thanks
I haven't taken this Xperia apart but it should be, I haven't seen an Xperia where the LCD it's fused together with the Digitizer
unrelated topic, if you have some time please check this thread
Hi All,
checked with another service center person, He opned the phone and checked
- Display is excellent
- Motherboard and other things on upper half of the phone is Good. No water entered there.
- Even touch is good.
- Problem is with connector strap which connects touch with main panel which is corroded.
Guy said only that stap can be replaced and sent phone to headoffice service center.
Not sure if one can get that connector strap seperately. if that is the case there will save huge amount of money.
Above picture points to corroded connector part in my case these connectors are not good. Can Only this part be replaced? Didnt see anyplace about how this can be opnened and replaced.
Thanks!
not quite
http://www.xperiablog.net/2012/04/30/xperia-s-disassembly-guide/
Hi uliwooly
I have seen the images which you have shared above.
Didn't get what you are saying. Does this means I have no option other than Replacing the LCD and digitizer?
Thanks,
Gourish
yes
Its been over a month! Still i havn't received my cellphone. Sony authorized service center has requested a new spare part. but its not sent by Sony yet!
Called Sony call center the gave our Reqional Head cell number, when I call other side he doesn't even pick the phone.
My pride Sony Xperia S though it was expensive, bought it with saving money. Now looks like all went waste, with this pathetic delay in service have lost all hope on the phone.
Its not a pride anymore.
Planned to buy Xperia Sola for my wife, thinking twice now.
If its replacing LCD and digitizer there is no point in replacing!
