While updating to the "latest" software, my phone turned off and won't start again.
When I try to turn it on, it shows the Sony logo first, then the image in the picture I've attached. Then it turns off again. I've started it repeatedly, but this keeps happening and won't turn on.
What can I do to fix this?
Solved! Go to Solution.
You need to run a repair using either PCC or SUS I prefer SUS found here emma.extranet.sonyericsson.com/update_service_setup Download - Install and follow the onscreen instructions
