Is there a difference mobile BRAVIA engine 2 or without it?
SOLVED
prodigy
Contributor
hello. I tried to see differences between the phone with BRAVIA engine and without it, but I couldn't see any difference. May I didn't notice, but for my bare eye I couldn't see any single difference. Now BRAVIA engine is off on my phone and still I find it like it was with bravia engine. Can anyone prove that there is a difference? Thank U.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
if you turn it off, you will save battery, the only disadvantage is that pictures/vids are not going to look as awesome
5 REPLIES 5
Uliwooly
turn on BE2 > open a picture > take a screenshot > turn it off > open the same picture > take a screenshot > compare them
prodigy
Contributor
Hello .Thank U for your respond. Yes U're right , there is a difference between the two photos. But for the bare eye and a quick lokk at the two photos U can't notice any different among them. Thank U again. BRAVIA engine has an effect on photos. I want to ask something: if I turn it off what advantages and disadvantages?
Uliwooly
prodigy
Contributor
Thank U so much. u were a great help. Thank U again.
Uliwooly
Anytime
