Hi, i have xperia u and in gingerbread simple games: (fruit ninja, mega jump) etc LAGS 😕 and 3D games woks smooth (Dead trigger) why this? :S help me please, sorry for my bad english, thanks.
Solved! Go to Solution.
Upgrade to ICS for LAG FIX
If you got time then please visit here:::::::::::::::::
TOP APPS for XPU::::
http://talk.sonymobile.com/thread/58158?tstart=0
Latest firmware ICS here and the guide to install it
http://forum.xda-developers.com/showpost.php?p=35339192&postcount=173
Custom Roms::
http://talk.sonymobile.com/thread/56689?tstart=0
If you are rooted then please visit
http://talk.sonymobile.com/thread/56641?tstart=0
http://talk.sonymobile.com/thread/56642?tstart=0
If you want to root:
http://forum.xda-developers.com/showthread.php?t=1886460
Please Mark
while playing fruit ninja i have noticed that it lags heavily even though 200MB ram is available. i also noticed the same on my friends xperia p & s.
do other users experience the same? my friend with htc explorer can play this game without any lag at all. this is really humiliating....
dont think the problem is with the app as other phones work excellent with this app.:smileysad:
Not on my xperia u. I have never noticed any lag on mine for any game including temple run and fruit ninja. Lots of background apps might be causing problems. Check for the app that is causing trouble and uninstall it. Restart your phone atleast once a day that will clear off memory occupied by unwanted and unused apps.
Its sony fault,and they didnt took sirius this bug.
Last time when I reported that directly via chat support they disabled my account!!!
Anyway its not RAM problem so dont listen anyone who says to you thats RAM problem because phone lags even if no apps is installed.
so now I regret buying 2012 xperia phone because it lags more than my old xperia X8 but just works faster.
No lag whatsoever in my phone. Just repair it if you want.
You guys are blind,xperiaU is right.
Some of my friends also say that there is no lag but there is and its visible.
all the apps run without any lag on my phone except for fruit ninja.
so i am specifically ashing about fruit ninja. i already have advanced task killer installed so that i have around 180 mb ram free atleast.
i had a similar problem previously.
try installing "advanced task killer" from the play store. its free & best.
i wasnt talking of the phone in general!
i was specifically talking about fruit ninja.
did u try fruit ninja on your xperia u?
hi xperiaU.i am having the exact same problem nd not only with fruit ninja but also with other games such as box cricket and ninjump,whereas my friend's galaxy fit can play this games smoothly...as u said its quite embarassing!
