I've tried to change my lock screen wallpaper,via Settings > Display > Lock Screen > Wallpaper
But the change does not actually apply. Despite it saying "Setting wallpaper" the change is not actually applied.
Is there also any way to change the clock on the lock screen?
Solved! Go to Solution.
It only shows a seperate wallpaper on the lockscreen if yo have the slider.
If you have pin or pattern, it shows the homescreen wallpaper.
Thanks.
If anyone from Sony sees this, it'd be nice if the wallpaper change was reflected across any security type. I imagine most people do use some form of security these days.
Agree, seems to be another silly feature from Sony.
