lockscreen on ray 2.3.4 - Removed? Ant+ enabled?
SOLVED
Not applicable
I have just recieved the android update, but now the cool lockscreen is missing. Its the fading television picture that I am thinking of. Is this removed from this android version?
On the positive side I have found that I now can use a ANT+ heartrate monitor with the ray. Thats cool because I didnt think that the ray had ANT+ support.
Regards
Lasse
1 ACCEPTED SOLUTION
Accepted Solutions
slimshaddy
Hero
unfortunately the crt animatin has been removed Slightly_frowning_Face
we all loved that animatin..was so cool..
and now its like fadi in and fade out..right ??
we cant change it 😐
its k.,.we can live with that Slightly_smiling_Face
7 REPLIES 7
slimshaddy
Hero
we cant change it 😐
Not applicable
Thats a shame, but thanks for the reply! But the ANT+ is really cool, now I just need a good fitness app that support trainingpeaks.com and not all the other "I workout once a year and want to share it with grandma" sites. 😉
Lasse
slimshaddy
Hero
i dont have any idea of ant+ thas why i dint reply for the same Slightly_smiling_Face Dizzy_Face
Not applicable
Its a wireless protocol a bit like bluetooth but MUCH less battery draining. You can then connect heartrate monitors, powermeters, and other equipment to the phone, to display the information garthed from the sensors.
Lasse
slimshaddy
Hero
oh okz its really nice Slightly_smiling_Face
Uliwooly
slimshaddy
Hero
nopes..its not working as its supposed to..
