LT28h restart with large noise
SOLVED
acsakvith
Visitor
Hi,
I just bourght xperia Ion lt28h, but when i plug the handsfree phone screen goses black and comes a large distorted sound from handsfree and restart,
very annoying cnt play any sound from handsfree,
also tried new software update, factory reset even diffrent handsfrees. but no luck
Is this a hardware issue??
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you should take it to a sony repair center.
5 REPLIES 5
acsakvith
Visitor
This happens when, battry is full, when battry is low, no problem handsfree works,
Uliwooly
repair your phone with either PCC or SUS to narrow down the issue
RELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
Uliwooly
acsakvith
Visitor
Repaird several times, but no luck, when the battery is full i cant connect the hands free, phone restart.
but in the evening i can connect and play music for while, but still it goes after while, same with video player and other players as well.
Really sad Slightly_frowning_Face
Uliwooly
