Media sound not working in Xperia P
narefeen2003
Hello everyone,
I play asphalt7 in my xperia on regular basis. There was no problem. Last night when I opened asphalt,it opened silently, though my phone wasn’t on silent mode. And after that my whole media sound is not working at all. I have tried in every way to bring it back; even I have done factory reset. But still no media sound (which includes Walkman, apps , video).please help!!!! Slightly_frowning_Face
thanks in advance for ur help
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Blazekick
try plugging in your earphone and then remove it. mine happens some times i plug the earphone and remove it and it works! Thinking_Face
12 ANTWORTEN 12
narefeen2003
by the way my ringer and alarm sounds are working fine
Henke
Vielschreiber
Try to restart the phone.
Check if you have certain apps installed such as: Battery saver-app, Task manager, Task killer-app, Anti-Virus-app.
Uninstall those apps and see if the problem is solved
What happens if you reinstall for example Asphalt 7?
Same result?
narefeen2003
told u i have done factory reset!it wipes all application as well settings.but no result
Blazekick
narefeen2003
it really worked!! Face_with_open_Mouth Face_with_open_Mouth is there any permanent solution?? its really a awful problem!is it a hardware problem??
profile.country.RO.title
_alexdon_
Not all of us experience this issue.It sounds more like a software glitch.
alexdon
narefeen2003
now im updating to 6.2.A.1.100 firmware...hopefully it has less problem then the preivous jelly bean update
Blazekick
Please mark as correct answer! Slightly_smiling_Face
StarkBeast
I have the same issues with my Xperia XA1. I bought the phone few days ago, updated it to the latest xperia software. Everything works fine then suddenly the media audio is not working (no audio for mp4, mp3) but ringtone, notif sound, and headset working. Done resetting it, rebooting it, and removing the earphone back and from but still did not work. Need help here. Thanks
