message problem
SOLVED
byrm
Visitor
message problem
hi, as you know xperia s keyboard remembers the most frequently used words and recommends them to us while typing..how can I reset this settings?thank you..
1 ACCEPTED SOLUTION
Accepted Solutions
Johan
Master
I suggest that you clear data for the keyboard.
Settings > App's > All.
1 REPLY 1
Johan
Master
