my phone wont turn on
SOLVED
ilija
Visitor
i was updating my phone sony xperia tipo, and the pc turned off. Now my phone wont turn back on the green light at the top just flashes and the phone wont tun on please help me what can i do ?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
first recharge your phone (wall charger) and then try again
6 REPLIES 6
Uliwooly
Uliwooly
ilija
Visitor
my pc turned off in the midle of the update, do you think recharging whould help becouse my phone  was fully charged when i was updating
Uliwooly
the update process drains a LOT of your battery so it will be wise to charge your phone
ilija
Visitor
thank you your advise worked :smileygrin:
Uliwooly
of course it worked, I am AWESOME!!! Dizzy_Face
