hey while connecting usb pendriv the ones with led lights to phon through otg cabl the phone says more power consumption so disconected.is there any solution to it..??
pls rply ty..:)
Solved! Go to Solution.
Ya sure. Nothing for larger PD's with lights and stuff. ICS will come this week.
use a smaller PD without lights and stuff.
yup figured dat out bt for pds wid light no solution,,?:( tnx fr ur rply:) pls do tell d link for ics wn u get it..:)
ok tnx...n u said rit now dat ics is releasd..from wher can i update it??
