Problem in recording Videos
SOLVED
hawkiq
Visitor
Hello guys, am new to Xperia phones so forgive me for my panic :smileygrin:
when using camera on my Arc S its working normally even if I record a Video whatever is the res.BUT when I try to play it
it show me this error and stop playing,
if its continue to play its will be laggy and without voice
My Software is GB and this is my phone info
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
on your PC
1) open any folder -> click on tools -> properties -> view -> show hidden files
2) mount the SD card, go to your SD card, press Ctrl + A then Ctrl C, on your desktop create a new folder, open it, then press CTRL + V
now you can reformat your SD card.
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
8 REPLIES 8
Uliwooly
there might be an issue with the SD card
but first backup your phone and repair it with SUS
Uliwooly
Uliwooly
if that doesn't work then backup your SD card on your PC and then reformat your SD card
settings > storage > unmount SD card > wait > format SD card
Uliwooly
on your PC
hawkiq
Visitor
I've tried with 2 SD cards and the same probleam, I'll try the Repair and back to you.
Uliwooly
you can also try
settings > apps > all > camera > clear everything
to back up your SD card
on your PC
hawkiq
Visitor
Still the same problem, and SUS dosen't have repair option Slightly_frowning_Face
Uliwooly
SUS should give you an option to install (re-install) the current firmware, have you flashed your phone? debranded? etc?
