problem with office reader
SOLVED
Not applicable
I had office reader installed in my phone but it says it needs update. I updated it but it says that application fails to install. What should I do. Is there any Method by which I can irecover the app. Pls help.
1 ACCEPTED SOLUTION
Accepted Solutions
slimshaddy
Hero
go to settings > applications > manage applications > all
find the office reader app.. select it and click on uninstall updates..
1 REPLY 1
slimshaddy
Hero
