Reset original Rom for Acro S
SOLVED
iAbdulla
Visitor
How can i reset tho original Rom for Acro S ?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
if you still have Sony's firmware either repair your phone with SUS or PCC
5 REPLIES 5
Uliwooly
Uliwooly
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Uliwooly
if you have a cutom ROM you need to flash your phone
How to manually update, downgrade, root 2012 Xperias
http://talk.sonymobile.com/thread/41609
iAbdulla
Visitor
No. i didn't have custom Rom
i just root my mobile and want to reset the original Rom agine to remove root
Uliwooly
ok, use SUS or PCC (link above) or flashtool either or will work
