Hey, I bought an Xperia S a week ago and I noticed something. When the phone is on the main screen, i tilt the phone but nothing happens it stays vertical, this happens on the notes too. I tried to do the same thing when the phone was charging, the same problem didn't happen, the screen turned. Is this normal?
Solved! Go to Solution.
the homescreen will only rotate if its connected to a wall charger or computer
there are some apps that do NOT rotate at all
unrelated topic, if you have some time please check this thread
go to settings > display > auto-rotate screen must be selected
there's an update on a Sony app that cause this issue too
settings > apps > all > smartconnect > uninstall updates
restart your phone
It doesn't rotate only on the main screen and notes screen, it rotates otherwise
Thanks, one last question. Can i change that with an update or something?
the homescreen wont rotate
unless
1) you install another home launcher from the play store
or
2) mod the current home launcher so it will rotate all the time.
as for the app, it's up to the app developer to add that feature
