st25i any Arabic Firmware Please
SOLVED
abo_mariam
Visitor
I have flashed my phone with the French ICS From here
http://forum.xda-developers.com/showthread.php?t=1918920&page=1
And now I want to go back to my original Arabic Firmware.
Can any one help me and tell me how to get the original Arabic Firmware.
My phone "SI 1261-8812"
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
abo_mariam
Visitor
I have done it Slightly_smiling_Face
I updated to ICS (the French version) and then Root it.
And the I edited the build.prop file, change SI to (SI 1261-375) It's the Arabic Customization
And I forced PCC to update (actually downgrade) It downloaded the files but didn't flash them
I took the files and used the flashtool and created a .ftf file and the flashed it.
And now I have the original GB .184 with Arabic Customization.
^_^
34 REPLIES 34
Bardia
Visitor
It hasn't araic keyboard or language ?! you should wait for original ICS for 1261-8812 ,like me.but i waited for Persian Language.French ICS hasn't Arabic or Farsi Keyboard ?!
you can also use pervious GB Firmware,if you can find it.but i don't know it works or not.
abo_mariam
Visitor
Actually I has Arabic Keyboard. But it dosent has Arabic Language.
And I hope to Find the original GB Firmware.
Bardia
Visitor
it's better to wait for Original ICS for Middle East ( SL 1261-8812 ). it will be release soon.keep waiting...
abo_mariam
Visitor
Is it (SI 1261-8822)?!
My phone is (SI 1261-8812)
Bardia
Visitor
So sorry,i meant 1261-8812 ... i edited my other posts ...
Bardia
Visitor
BTW  SL1261-8812 is for Middle East's Countries and supports Persian and Arabic languages ...
abo_mariam
Visitor
If you have a Middle East Phone like me (SI 1261-8812) Could you please back your firmware and send me the .ftf File Please.
Bardia
Visitor
i will search it for you
babak
Visitor
bardia jan baba ba flashtool bezan felan ta badesh vase khavar miane biad
man ham aval rom france ke vase st25i bood nasb kardam ye mosht barname faransavie birabt toosh bood
badesh zadam romi ke aval oomade bood nasb kardam albate in vase st25a bood vali age tike baseband moghe felash bezani moshkeli nis
alan dare dorost kar mikoneo ba hamin flashtool rootesham kardam
felan estefade mikonam ta khavar mianasham biad bad oono nasb mikonam
inam khoobe hich moshkeli nadare faghat keyboard farsi nadare ke oonam ye keyboard nasb mikoni , khodesham ke kolan zaboon farsio support mikone Winking_Face
