Hi, I just got a Sony Xperia TX yesterday and noticed a symbol (Pictured in the red circle) on the top bar of the phone. I couldnt find it on the satus and notification icon overview in the manual. What does it mean? I looks like a battery between to curves lines.
Solved! Go to Solution.
That's the symbol for extended standby mode. You can de-/activate it under Settings > Power management.
