Two days old Xperia with almost dead battery
SOLVED
Oveja
Visitor
Hi
Monday i bought the Xperia U and i've charged it until was 100%, but battery lasted 3.5 hours.
I've charged again overnight and again, it lasted almost 5 hours.
I've tried to calibrate the battery erasing all the data, and then the whole procedure and nothing, the battery lasted 4 hours barely.
I dont think this is normal, 'cause its only a 2 days phone! and the battery its already failing. This happened a lot or just me?
Oh, i've upgraded to Android 4,0 the same monday,
What can i do, do i recalibrate again and again the batery or i have to change the phone using the waranty?
Please help, thanks!
1 ACCEPTED SOLUTION
Accepted Solutions
jatinrungta
Enthusiast
Do a repair via SUS immediately
And also keep standby mode on
Settings> Power Management
WELCOME TO THE FORUM
If you got time then please visit here:::::::::::::::::
TOP APPS for XPU::::
http://talk.sonymobile.com/thread/58158?tstart=0
Latest firmware  ICS here and the guide to install it
http://forum.xda-developers.com/showpost.php?p=35339192&postcount=173
Custom Roms::
http://talk.sonymobile.com/thread/56689?tstart=0
If you are rooted then please visit
http://talk.sonymobile.com/thread/56641?tstart=0
http://talk.sonymobile.com/thread/56642?tstart=0
If you want to root:
http://forum.xda-developers.com/showthread.php?t=1886460
Please Mark
  • Correct Answers
  • Helpful Answers
3 REPLIES 3
jatinrungta
Enthusiast
Custom Roms::
Please Mark
  • Correct Answers
  • Helpful Answers
Oveja
Visitor
Thanks!
I've chated with a SONY employee and he said that i needed to repair the version of Android and i instaled it again.
After that, the battery lasted 6 hours to 49%  so im hoping that the battery it's more than OK.
'Im using the Hold Mode (i hope thats OK, my english isnt so good), and that helped 😃
I'm hoping that it wont fail again.
Thanks again
jatinrungta
Enthusiast
Glad
PS
Uninstall
ANTIVIRUS
TASK KILLERS
RAM MANAGERS
AND ALL
THEY DO MORE BAD THAN GOOD
PS
YOU CAN MARK AS CORRECT ANSWER IF IT HELPED
