Unabe to set track as ringtone after Jelly bean update in Experia P
SOLVED
SoniaBansal
Visitor
After Jelly bean update, when I go to Settings-> Sound -> Ringtones , option to open Music Library and select a track is not available. Only installed ringtones can be selected.
Please help, this was working very fine earlier.
This problem also occurs with Notification and Alarm sound.
1 ACCEPTED SOLUTION
Accepted Solutions
Sam
Legend
Legend
It depends on what you selected as "always". All you need to do generally is navigate to Main menu > Settings > Apps > All > Locate the program you selected as "always" and tap "clear defaults".
What are your thoughts about this forum? Let us know by doing this short survey.
18 REPLIES 18
profile.country.PH.title
MarlonUk1
i dont know why it was removed on JB, try this
http://www.youtube.com/watch?v=jIiSd1AWWeo
profile.country.RO.title
_alexdon_
Of course it is available,I have a song as a ringtone.In ringtone,you have a music note in the right corner,thats where you have to tap.
alexdon
SoniaBansal
Visitor
I was able to get this option before Jelly bean update!
Can you please share the snap shot?
_alexdon_
Ignore the language (romanian) please.
alexdon
SoniaBansal
Visitor
I could not see the Tap option after the Jelly bean update. I can only see Phone ringtones.
_alexdon_
Very strange,the option should be there for you too,give me a screenshot of your sounds(settings).
alexdon
SoniaBansal
Visitor
Please find below the snap shot. Let me know what could be done.
_alexdon_
Ok,here everything is ok,now go to phone ringtone and give me a snapshot there,or is it the one you posted before?
alexdon
SoniaBansal
Visitor
Yes, the earlier snapshot was the screen which opens on selecting Sound->ringtones.
Earlier  I used to get option to select Music Library, after I updated my phone to Jelly beans yesterday,I could no more find that  option.
Nor do I find option on  a track to set as ringtone.
