Unable to view my clicked pictures on my PC. Pls help
SOLVED
a_agarwal
Visitor
I have clicked a couple of pictures on my phone that I want to send someone. However, these pictures are not visible either through the PC Companion, oreven through directly exploring the phones folders (My Computer). It is only showing the preloaded pics.
I've even tried taking a backup of the phone, just in case.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
Well,if you want the full pictures and you are exploring with My Computer,enter Xperia P and go to dcim,and after that select 100_andro or something like that,there should be the pics.
alexdon
5 REPLIES 5
_alexdon_
What do you mean with preloaded pics?Thumbnails?
alexdon
a_agarwal
Visitor
Yes, I guess thumbnails will be the correct term for them. But how to view the pics I clicked?
_alexdon_
alexdon
a_agarwal
Visitor
Thanks. There should have been a separate folder for the pictures, like there is for the videos.
_alexdon_
Agarwal,you are welcome.The videos are not in a separate folder,what is shoot with phone camera is in the same folder,100andro.The videos folder you see there are for your videos,which you can upload on the phone.
alexdon
