I have seen people posting about support of USB OTG for pen drives with Xperia U ( http://talk.sonymobile.com/message/288939#288939 )but why Xperia Sola doesnt support USB OTG to connect pen drives.I have tried many pen drives but nothing works.
I formatted pen drives using NTFS and FAT 32 but both ways did not work. Used several brand and several size pen drives but no help.
Am I doing something wrong?
Solved! Go to Solution.
its jus a simpl cabl ,i buy it from market..no model or smthng
pen drive working in my phone
Its working for you...Thats great!!!
Is it working on xperia Sola!
Which brand pen drive and what is its size?
Also please tell me the cable you are using to connect pen drive, any model name/number and where did you buy the cable from??
yes its working on xperia sola,,as u can see in setting-storage
thy have option for it
make one thng sure before connect that ur battery level is more than 50%
well its not working for me even if the battery is fully charged:-( it will help me if u tell the model no/name if any of otg cable u r using. thanx farooq
I think you got a bad cable. Try another one from ebay. I have used Kingston 8Gb, Sandish 8Gb and HP 16 Gb without any issues with Sola and a cable from ebay. Its a generic cable so no specific make or Models.
