Xperia Mini Pro 2.3.4 (4.0.2.A.0.42) Thanx XDA forum, Raph4 & ajzak
Get the ftf files here
http://forum.xda-developers.com/showthread.php?t=1321948
get the Flashtool From here
http://forum.xda-developers.com/showthread.php?t=920746
Install it and you will see 5 folders
This is an step by step guide
5.a. Unplug your USB cable from the PCb. Power off your phone and plug the USB into the phone
c. Press back button and keep your finger on button
d. Plug USB cable into your PC whilst holding down the back button on your phone
e. A green LED will appear
f. The process will automatically detect your phone and start flashingg. When "Found at USB/........" appear on flash tool you may release"back button", sit down, relaxand wait.Hope this is helpful to you6. IF the "Start Flashing" message appear everything`s ok if not...repeat. Sitdown and relax (again )
7. When last message appear unplug/plug USB cable
Regards,
Ricardo Rendeiro
Solved! Go to Solution.
Hi what firmware to download if i am from europe and i want greek language ?
Thanks!
