Xperia S Sound Problem
SOLVED
Not applicable
hei i have an xperia S i notict that my phone dint do anny shutter sound when using the camera app .. i tried reinstaling the software and still had the same problem after i conectet to my google acount ... then i noticts this applys to all sound like the unlock screen and button touch and so on ..
reinstaling works until i connect to my google acount. i checkt all settings and they are turnd on and the sound is maxed out ...
im not shure what causes the probelm but a software update from .73 to .75 dint help .. a total reset dint fix the problem ether...
anny idea?
11 REPLIES 11
martinvoronak
Visitor
so i figured out what did you mean by "this app" (download from google play) ...it still doesn´t work
martinvoronak
Visitor
i was surfing the internet and my solution was this page http://kevinpotgieter.wordpress.com/2012/07/27/sony-xperia-s-ics-update-fail-no-call-volume/ ...just needed to plug and unplug headphones coz last time i was hearing songs when it was plugged nad it didnt noticed that headphones are unplugged (something like that) ...hope that this will help anyone with this problem
