Solved! Go to Solution.
This might be intersting/helpful
http://batteryuniversity.com/learn/article/how_to_prolong_lithium_based_batteries
Nope..SP use Li-ion+ batteries...in this kind of battery no matter that when you plug charger or when unplug...but one thing..dont let the battery drain completely
Do your screen easily get HOT in just a short time of using the phone? and
how long your 100% battery drain? in extreme using of the experia sp. like playing with the phone or using the 3G. because i notice my experia Sp phone have a little life span of battery. I can use it like 1-2 hours only and it will 2% battery. and it makes me pissed because i bought it 1 month ago. can someone tell me if is it natural. or something wrong with my battery?
