Xperia u dpi problem
SOLVED
shivam11396
Visitor
hey..
i had rooted my xperia u(ICS) by flastool..
i accidently set its dpi using density changer to 50(which should not be less than 130).. Slightly_frowning_Face
and now my phone does not opens up.... PLZ HELP... Slightly_frowning_Face Slightly_frowning_Face
any one... ?
1 ACCEPTED SOLUTION
Accepted Solutions
jatinrungta
Enthusiast
Nope I use Windows 8 too. Install flashboot drivers from Flashtool>Drivers folders
If you got time then please visit here:::::::::::::::::
TOP APPS for XPU::::
http://talk.sonymobile.com/thread/58158?tstart=0
Latest firmware  ICS here and the guide to install it
http://forum.xda-developers.com/showpost.php?p=35339192&postcount=173
Custom Roms::
http://talk.sonymobile.com/thread/56689?tstart=0
If you are rooted then please visit
http://talk.sonymobile.com/thread/56641?tstart=0
http://talk.sonymobile.com/thread/56642?tstart=0
If you want to root:
http://forum.xda-developers.com/showthread.php?t=1886460
Please Mark
  • Correct Answers
  • Helpful Answers
4 REPLIES 4
Cryo
Visitor
Is it still detected by PC?? if yes then install the stock ICS ftf via flashtool.
jatinrungta
Enthusiast
Welcome Here that has happened to me too
if you did a backup Just restore it
if not flash only the system from Ftf ie Exclude everything except system and voila fixed or search for  build.prop Flashable zi. IF you got cwm
Custom Roms::
Please Mark
  • Correct Answers
  • Helpful Answers
shivam11396
Visitor
no.. it doesnt recognnize my cell in flash mode... Slightly_frowning_Face
is this prob due to win 8.. ?
jatinrungta
Enthusiast
Custom Roms::
Please Mark
  • Correct Answers
  • Helpful Answers
