Have I ruined my Sony A95K OLED TV?
Valkyranna
Found a small smudge on my screen, probably finger prints as I was reaching around the back to plug in a cable the other day, went to wash it off with the cloth I use to wipe my glasses as eye glass cloth was recommended to clean my OLED screen and the smudge has got worse and I feel I've damaged the screen. I only bought this TV in January so I should still be covered under warranty but feeling terrible today as a result of this.
20230512_152322.jpgImage attached to show the damage. Is this still able to be wiped off? It doesn't affect the overall image, its only noticeable on an all black background with a slight dark patch on bright white elements so it may only be the reflective coating affected.
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
Tags (4)
3 ANTWORTEN 3
Sonearly
I have a long line across the top of my screen that looks very like your larger smudge, I tried removing it only to find that’s it’s actually behind the screen and there’s no way to get to it. Hope you find a solution.
NINJATHEORY
Hello, your asking can it be wiped off mate you got the t,v in front of you have you touched the patch ? does it feel rough ? and where did all that dirt come from ? what chemical did you use when you were trying to clean t.v  ?
Anonymous
Nicht anwendbar
Oh no, sorry about that mate :(. That's the proper way to clean your TV screen: https://cutt.ly/ywqsLnl5.
However, if this spot won't come off the screen the only way to proceed is to repair the TV itself, and don't try to use any other substances or materials to clean it so you won't damge it further.
