Laptop VGN-B3VP not starting (seems to be booting problem?)
rajesh525
Visitor
My laptop was working fine till yesterday evening. Today morning, when I tried starting the PC, it didnt start. Checked the power supply, was working fine. Removed the battery, inserted again and recharged, still wasn't working.
Is it a booting problem?
Guys/gals am not a technically sound person. Hence, if u can guide me with simple troubleshooting process, that'll be much appreciated.
Thanks in advance
Rajesh
12 REPLIES 12
MattWilson
Visitor
Well sony know there machines best so i would always suggest them.
Maybe the local computer repairers - you could ask that if they find no problem (can't find it) that they do it for free. If it is a small company then they usually agree and i usually get it done quicker and try harder. Worth a try.
Good luck :slight_smile:
Let me know how it goes.
rajesh525
Visitor
Sure, will definitely let you and others know what the outcome is. Thankx for all your advice.
MattWilson
Visitor
You are very welcome :slight_smile:
