Hallo everybody!
I have a PCG-GRT815E and a problem with the fan.
It became every day noiser and noiser, up to know the speed is so fast that it will take off soon!!
Do someboby experience the same problem?
Thank you all!!
Mauro
I don't think any of you have been at all helpful.
Now let's get back to the point. Fans wasn't it?
Would they be like ABBA fans or Rolling Stones fans? I guess the Rolling Stones fans would make more noise but you can never underestimate the public's desire for a bit of ABBA.
Not me though.
Hope that helps:smileygrin:
i prefer movie theme song.. especially superman,batman,indiana jones,star wars etc ect
ROFL and you can't beat a bit of New Order thrown in for good measure...:smileygrin:
I like all sorts, I'm not going to post them all here....
well, with nichelback and linkin park, my fan is pretty silence!
Thank you all for helpin'.
I have recovered the c: with the recovery cd.... it seems to be better... but I do not trust it very much... I suppose it's just because there're less running task
I will let you know...
enjoy the life!
I like a bit of Linkin Park too.
Good luck with the machine!
Ok , now, I told I will let you know...
well, I have recovered... twice!!
The first was ok for the fan but some "nice" features of xp sp2 were really really orrible working with photoshop 7. (no preview, system slow etc)
The second one (this actual one) is ok (no xp sp2 installed, just some hot fix) BUT .... the fan is still noisy!!! even if not as noisy as before....
I'm a little bit frustrated :smileyfrustrated:
Now: 2 solution:
1. buy another laptop (still vaio? mmmmmmmmmmmmh) since I have to work! (I'm a photographer)
2. try to open it and take a look (the warranty is expired)
AAAaaaaaah another thing : "burn your own DVD recovery..." ....HOW??
10xs a lot
well if you go to start/all programs/vaio recovery tool/vaio recovery utilities.exe it will show you how... you will needed either 6-7 cd-r or 1-2 dvd-r good luck
You could try #2
