hi can any1 help me im having c=wireless connection issues. my internet only works in the room of the router. any other room it disconnects. any suggestions would be helpful.
thank you
Try this - quite fresh from SONY but not sure if this is of any help actually:
https://ca.en.kb.sony.com/app/answers/detail/a_id/43725/p/48903,4990,74253,85577/c/65,67/kw/43725
thanks ill give a shot x hope it works
Try the suggestions in takrzem's link above first.
Make sure you have the latest Broadcom Wi-Fi driver update v.6.30.223.181 installed from the support page for your model here: -
http://www.sony.co.uk/support/en/product/SVF15A1M2EB/updates
If that does not help, you will need to contact Sony Support as this is a known issue.
hi followed those links and did as recommended but still no effect. any other advice ?
thank you for your help everyone x its working alittle better, one of those links must have done something to fix it. thank you again x
