What Is A Good Quality Battery For VAIO VPCCA Laptop?
I_Luv_Orange
Hello,
I have a Vaio laptop, model number PCG-61814M & I’m looking to replace the battery. Finding an original is proving few & far between. I’ve seen many on eBay from £18.99 all the way up to £50-£60?! All are third party ones.
Can anyone recommend a good quality one as I don’t want to buy one that’ll last 5 seconds. I’ve seen GREEN CELL batteries for around £40, abit steep for me, but if it’s worth it, then I would buy that.
I would like your option.
Cheers.
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
I_Luv_Orange
Hey. Thanks for the link. Unfortunately £90 is out of my price range. :open_mouth:
6 ANTWORTEN 6
Sean_Mc
Moderator
Hi there,
Welcome to the Sony Community.
It would be best to get in touch with the support team who will be able to advise you on this further here.
Best wishes,
Sean Mc
I_Luv_Orange
Hi Sean,
Thanks for your reply. I will see if I can do that. Cheers :slight_smile:
profile.country.IT.title
Marino.Manolo
I_Luv_Orange
Charmina.n
Hi, did you find a cheaper battery that works? I have been looking to replace but so hard to find a genuine Sony battery. Tried couple of cheaper ones that don’t work.
Joe_Dohn
Spezialist
Have you tried taking a look at this thread?
